Speed Pulse Signal - 2006 NC with Bose
  1. My model of MX-5 is: __2006 NC with Bose
Hi Guys - would anyone know where I can pick up the speed pulse signal on a Bose equipped car ?
I have had the stock head unit out and the speed pulse wire is not in the loom coming to the back of the head unit. ( should be at pin location 1I )
The Haynes wiring diagram is as much use as a chocolate fireguard.
Guessing I will need to pick the signal up from the back of the clocks but can’t find any info on the clocks wiring.
Cheers
Hmm, I only have the US wiring lifted from Mellens a while ago, so this might help, but no guarantees
Look for the only plain White wire leaving the instrument cluster, should be on pin 2O
Cheers - will take a look.
