I’m looking for technical help or recommendations on: __speedo
Hi, Car is new to me. Speedo has just stopped working. Where should I start to look for a solution. Recently had OS front off because of poor seating of tyre.
Ok Thanks. A couple of things to check out.
I’ve a Foxwell 530 for Volvo but it does generic as well. Looks like the speedo readings are off the rear wheel NS.
If it’s fallen off its spindle that looks like a whole lot of grief just to get to it to press it back.
Ok. Checked on my OBD scanner and it is showing vehicle Kph when moving. So assume it’s the actual speedo needle has come loose or are there any other possibilities? Done a search but can’t find any on here to suggest how I get to the needle.
Further help needed: Thanks
The instrument cluster is pretty easy to remove. The top half of the column cover just unclips as does the instrument cluster cover. The instrument cluster itself is held in with 3 cross head screws, 1 top centre and 2 pointing up from underneath at either side, remove those (you may have to remove the lower steering column cover to gain access which is held on by 3 screws), pull the cluster forwards a bit to gain access to the back and unplug the 2 electrical connections and the wiring harness clip (rotating it 90* anticlockwise if viewed from the back off the cluster should allow it to come out). There are 4 cross head screws in the back of the cluster that allow it to be taken apart.
If this is unsuccessful, I reckon it’ll be a failed instrument cluster. The speedometer is operated by a microprocessor within the instrument cluster based on the speed signal from the PCM which is sent via CAN. It could either be a faulty speedometer, faulty microprocessor or faulty circuitry within the instrument cluster. The tacho uses the same circuitry so if that works then the PCM is sending signals and the instrument cluster is receiving them. I suppose there is a slim chance that the PCM is not sending the vehicle speed signal but if the odometer is counting up then it must be. I assume that it is, you haven’t confirmed.
You can carry out an “Input/Output” check on the instrument cluster which forces the speedometer to operate, the procedure is below.
Ignition off
Press and hold the TRIP button
Switch ignition on
Continue to hold TRIP button until “tESt” is displayed on the LCD
Release TRIP button as soon as “tESt” is displayed
LCD should display “01”
Press TRIP switch until “12” is displayed in the LCD
Speedometer needle should move to full scale then return to 60 mph reading
If speedometer needle does not move the instrument cluster has a fault
If you want to check that the procedure has worked, go to mode “13” and observe the tacho, that should move full scale then rest at 3,000 rpm.
If you get to grips with that I’d also be interested to know what the LCD displays on mode “59”. Just to confirm, your MKIII is an early one isn’t it? 6th from last digit of the VIN is a “1”.
Got it. I forgot to check if the mileage had moved, which would also suggest a solution if it had or hadn’t.
I’ll give it another spin and try your electronic checks before getting the screwdriver out.
The best outcome has occurred. After doing the procedure suggested by Robbie to force the needle swing( it worked) the speedo is now functioning on -the- road.
Be interested to see if this re-occurs, but ok for the moment. Thanks for your help.
