Hi all,
Just bought a MK1, 1.6 (91) UK car that has developed a squeal when you pull away in 1st gear. Sounds like a fan belt BUT it continues regardless of engine temp…
Any ideas?
Ben
Hi all,
Any ideas?
Ben
Erm…so does a loose fan belt. Have you checked its condition and tension?
If its not the fanbelt it could be spigot bearing in flywheel but hopefully not
A drop of washing up liquid on the fanbelt/pullies would quieten it to indicate if that is the source of the squeal.
Or a bit of chalk on the pulley and belt to see if it has slipped…
Yes - nice bit of simple diagnostic - will give it a spin. Thanks
