Standalone Plug-and-Play ECU options for the NC?
I’m in the process of purchasing an MX5, most likely NC, and I was wondering what options there’d be for a standalone plug-and-play ECU? Preferably something which isn’t too expensive as I plan to turbo the car on a budget.
Hi there , no suggestions on standalone ECU but not necessarily required for a turbo install on an NC see post below if you have not already seen ,
I think that guys on to something :wink:
Its only the MK1 and Mk2 that require a standalone ECU. The MK3/NC has a different system and with the right software can do pretty much all you want. ECUTEK is the main one used to tune, once you have paid for a license anyone with the software can tune the car.
ProECU MX-5 - EcuTek
Thanks, I’ve briefly looked at some of your posts the other day and watched a few of your videos. I was wondering why I couldn’t find any ECU’s for the NC apart from the ME221 and 441, although it makes sense if the standard ECU for it is enough.
So if I buy the ECUTEK software, I can program the standard ECU directly with it from a laptop?
Initially I think I’m going to buy a cheap turbo kit to see if I can do it, and try to tune the car myself before I pay someone else to do it for me.
Also quick Q; I’m assuming this kit I’ve found didn’t exist when you initially did your DIY turbo; Turbo Manifold Downpipe Intercooler Kit For 05-15 Mazda Miata MX-5 NC 2.0
It seems relatively cheap compared to other kits and will cost about the same as it did for your build (if I remember correctly)
Hi
Yes, you also need a one off license for the ECUTEK as far as I understand.
I’ve not seen that kit before, but I have to be honest the install looks pretty bad. I haven’t looked to closely at what it includes but a cheap turbo, no electronic boost control, hot air intake, no injectors, No higher bar MAF to name a few that jump out.
For the UK you would need to add on shipping and import tax, also getting it tuned which is which is in my cost.
Its not a kit I would go for, but that’s just my 2 pence.
Hmm I suppose it’s not a “complete” kit then, cheers
Hi, idk if i’m late but I just joined the forum, for a budget kit i found this:
