hi.
Anyone know the standard ride height (road to wheel arch) for a mk1, 1.6 eunos? as i need to adjust my GAZ coilovers to qualify for hillclimb and sprint
cheers Phil
hi.
cheers Phil
From the workshop manual—
Spec is: -
Rear 346mm - 395mm.
Front 328mm - 377mm,
The difference rear-front should be between 10 and 30mm.
thanks Geoff
had i looked harder i’d have found the answer in faq.
No worries Phil, takes a while to get used to the board—
Just a couple of pointers:-
It’s a good idea to put your rough location in your profile [this helps with us offering advice etc].
Also please put your car details in your sig, again helps when advice is being sought.
