Hi - in a nutshell my 1996 Eunos Roadster 1.8 Auto V-spec starts immediately the key is turned but then equally immediately dies. This can be repeated time and time again - it bursts fully into life as if all is well, then dies.
As I am new to my Eunos I am a bit at sea with all the complexity of the system (the last two-seater sports I had was a Spitfire 4!).
To give the background to this…
The car had been laid up for three years when I bought it from a colleague. On replacement of the battery it started without problem and I drove it straight down for an MOT (passed with no issues) and had a basic service. On collecting the car I drove a mile or so home with no problems and parked it on the drive. I started it once on the drive and the engine ran fine. Then I started it again and it died, and while it turned over, the engine was lifeless.
I consulted my Rod’s manual and started to work through things starting with the checking fuel pump/relay system. The fuel pump relay was fine but when I jumped the F/P to GND on the diagnostic block the fuel pump wasn’t working - actually, it didn’t, then did, then didn’t and then wouldn’t anymore.
I got the tank connection exposed, disconnected it and checked that indeed 11.odd volts were present at the connector, but when the pump was connected the load was such that the f/p relay immediately dropped out. I surmised that there was too little current in the circuit and checked the B+ on the diagnostic block to GND and got only just over 11 volts despite having 12.5 at the battery. As I was informed that the only thing between the battery and the B+ terminal was a 30Amp fuse and the main relay, I replaced the relay and the fuel pump is now running fine. Presumably the relay contacts were corroded or not making good contact - though even with the replacement I am only getting 11.9 volts at the B+ terminal now?? I also checked the grounding off the tank connector and the two GNDs off the diagnostic block and they all appear fine.
Anyway, that apparently fixed I was first elated that on turning the key it started and then dismayed immediately as it died as I have outlined above.
Now I know I should and will make up the diode/LED and check for any error codes, but could anyone who has more experience of the system suggest what could be the issue? What could possibly allow the engine to start so easily and well then cause it to die equally instantly?
The one thing I suppose could be a partially blocked fuel line and because the car stood for three years and was near to empty it could be that after driving it and sloshing the fuel around in the tanks the filters are semi-blocked. I added a gallon of new fuel with additive and rocked the tank to help clear any blockage, but that hasn’t helped. As the main fuel filter is right under the car and so is difficult to access is there a simple way to check that the fuel is getting through the system with the required ease? I thought that checking the flow in the return line at the connection on the tank would be easiest (as I still have the carpet and cover off) but this is best avoided if the problem is likely to lie elsewhere.
Thanks in advance for any experience you can bring to bear on this. Of course I could just simply, if expensively, get it towed off to the nearest dealership, but I want know my way around it technically as I bought this car as an enthusiast, and so it is a bit frustrating to be stalled before I get chance to get any real familiarity with it.
Paul C
