Steam From Radiator
I have a Eunos S-Special 1.8 Manual (1996). The coolant was looking quite rusty coloured so I changed it. It only took 5 litres of coolant to fill her, rather than the 6 Litres quoted, which I thought was a bit odd.
The car is off the road for winter (in a wooden garage) so today I decide to “turn her over”. I fired her up - all OK. But then as she got to normal temp (according to the gauge) steam started coming of the radiator. I turned her off straight away. There were no puddlles of coolant under the car before I switched her on, but there was an odd drop of coolant on the bottom of the radiator itself.
I am guessing I have a small pin-hole leak in the radiator matrix?
My question is should I try Rad-Weld or similar, or take her to a Garage and get her checked over?
Radweld is old technology .Try Nova Stop products are excellent and work every time for leaks etc.A bit expensive but guaranteed to work.
have you lost any coolant ?
No not really, a few drops at most?
I could be anything from a air blockage to a very slight leak from the rad but could be somthing like a leaking headgasket ect so its better to get it upto temp (make sure the heater is on full) and check for leaks or a drop in coolant as if its just a airblock the coolant level will drop that missing liter of coolant :stuck_out_tongue: if its a leak you will see it somewhere but if its a dodgy headgasket you may need a sniff test from a garage unless you have other signs like mayo looking stuff in the oil filler hole or a oily film in the coolant tank on the water :slight_smile:
How much steam? It could be just the radiator drying if the car has been stood
Not a huge amount, not clouds but I was only running her up to normal temp.
[quote=richardn]
Agree.  If no coolant lost, condensation is the likely explanation.
Regards  Geoff Peace
[quote=Geoff Peace]
Hope you are right! - will probably have to take the car for checks at the garage. Before my recent coolant change the coolant was very rusty looking, as is the Radiator Cap (inside). I suspect someone who owned the car before me did,nt put in the right strength of Anti-Freeze, and maybe the radiator is part filled with grot?
I had an overheating problem with my 1.8 Berkeley. Silted up radiator was the main cause. Very narrow core in these MX5 rads, so I am told.
I think I might have the same issue. I did try flushing the radiator when I changed the coolant but I guess you can only wash out so much. I might have to try a new aftermarket rad from MX5 Parts.
The cores in most radiators are very narrow, they silt up quickly if antifreeze changes are neglected.  In my experience trying to flush a radiator is, simply, a waste of time.  If it is blocked/severely restricted then the only remedy is a new radiator. Anyone who has cut one open will understand.  There used to be companies nationwide who would recore radiators in 24 hours.  Do they still exist?
Regards  Geoff Peace.
Looks like a new rad is the way to go!!
