- My model of MX-5 is: __2.0 sport mk3
- I’m based near: __Leatherhead
- I’m looking for technical help or recommendations on: __clue is in the thread title
Just had a nosey under the front of the car, which is sitting on full lock to the right. I noticed the front right steering rack gator is only connected on the outer end. The other has pulled away from the rack.
I have not had a look properly yet, but I am hoping that the rubber has just pulled off, maybe softened with the hot weather and sitting under tension on full look. The rubber doesn’t look worn or split, but does feel hard.
The replacement gaiter from MX5PARTS is £77!
Has this happened to anyone else? Do they tend to fail eventually at the inner end? Reckon I can pull it back on and cable tie it tight?
