The steering wheel on my ND is not centered (about 2 degrees to the right when travelling down a straight road). It has not been kerbed nor does it pull to the left, it is just misaligned, but very irritating! How easy is it to correct using the track-rod ends without altering the toe angle. Is it just a matter of screwing in one track rod and unscrewing the other by the same amount to re-align the steering wheel without affecting the toe-in angle?
Cheers Paul. I take it the threads on both track rods are normal right-hand threads and there is no stupidity like having a right-hand thread on one and a left-hand thread on the other. I am asking this because I tried to loosen the lock-nut on one of them and I couldn’t get it to budge. Maybe I need to get some penetrating oil on them!
Yes, that’s OK, but to correct just a couple of degress at the steering wheel, you’ll only need to move the track rods by the proverbial ‘gnat’s nadger’…probably about 15 degrees- or a maximum of one flat, and don’t overdo it, or you’ll get it out of line the opposite way!
A good way of breaking the grip on the track rod nuts is to put a snug-fitting spanner on both track rod end AND nut, then with their ends a few degrees apart, squeeze them together, so doubling the effective torque being applied to the joint. That, and a good sqirt of penetrating jollop beforehand, usually does the trick.
