I’m looking for technical help or recommendations on: Gear changing issues under certain conditions.
Hi all,
I’ve recently purchased and NC3 and having some peculiar issues with the gearbox. As most NC owners have reported, the change from 1st to 2nd isn’t great when cold and there is a notchiness to shifts but that was expected.
My issue is that after driving for about 20/25 minutes and/or driving in stop start traffic, all of a sudden it becomes very difficult to shift into first (or any gear) when the car is stopped. I do manage to get it in eventually after using some force but it is a very stiff change. Once I’m moving again the shifting is fine. When I go back out to drive a few hours later, all seems fine both when stopped and moving.
I will get this checked out by a mechanic soon but was wondering if any of the possible solutions I’ve found online are worth trying?
Clutch pedal adjustment
Gearbox oil change (However oil was changed about 250 miles ago with Redline oil)
Reverse gear lockout plate (will change this eventually anyway) and shifter turret oil
Clutch bleed and fluid change
Clutch pedal mount assembly replacement
Gear linkage check
Full clutch replacement with master and slave cylinder.
Any advice or your experiences would be really helpful
I had a similar problem last summer. I’m stop start traffic when hot, it was very difficult to engage gears.
Failing slave cylinder was the problem - but I had the clutch replaced at the same time as it was showing signs of wear,
I spoke to the dealer and he is willing to replace the slave cylinder and clutch as he spoke to mechanic who suggested it may fix the issue. Fingers crossed!!
You did very well to get them both at the same time. Normally, they would do the slave cylinder and see how it went.
Good luck and hope it all works out,(should do).
From an owner the same as yours.
If you bought the car recently and they changed the gear oil before handing it over you’ve got to query which oil did they put in? Incorrect grade can I believe give notchy gear changes, 75w 90 to GL 4 spec is the stuff you should have in. Plus you didn’t say how many miles the car has done.
Whoops you’re right. The car’s done about 84,000 miles but did have full main dealer history.
I will query about the oil used as well but I was told he contacted Bofi racing for advice so I’m hoping it was the correct spec but yes I’ll double check
I’ve been having a similar problem with my 5 speed NC at the moment, gearshift is really rough and needs a lot of effort to get it to go into gear (especially reverse), I’ve rebuilt the shifter with new components, fitted a 5x racing bronze bushing and adjusted the clutch free play it’s made it a bit better but reverse is still a pig to get into. It’s going in this week to get a newly refurbished slave cylinder fitted and red-line oil put into the gearbox. Hopefully this’ll fix the problem otherwise I’m probably looking at a new clutch assembly.
So I had the clutch, slave cylinder, and lockout plate replaced about 2 weeks ago now. First 2 or 3 days the shifts were light and felt great but I guess I got used to it and now it just feels normal but still better than before.
As for the issue with difficulty changing gear, I haven’t been in stop/start traffic long enough, or taken it for a long enough drive to replicate the issue but I’m hoping it’s fixed given there’s a new clutch and slave cylinder and it’s shifting better.
Also gear oil is confirmed to be the correct spec. Thanks for the help everyone
I think as long as gearbox specific oil has been used it a bit of a rabbit hole to say the brand or slight changes in viscosity is causing problems with gear changing.
Gearboxes, manual at least, haven’t changed much over decades. I used to have Ducati singles that ran on the same oil for lubricating the piston and the gearbox. And despite being a Ducati the only thing that didn’t go wrong with them was the gearbox😀
