Ive never owned an MX5 and have found onen at a good proce but i see from the mot advisories that all four Suspension arms are corroded but not seriously weakened and both the fron and rear Sub-frames are corroded. Please advise as to how much this would cost me to repair and whether i should go ahead and purchase the car.
I would not be too worried about this - common enough scenario with the MX5 as they were never really treated properly when first manufactured.
The thin paint layer soon disappears with salty roads and surface rust quickly coats the suspension and subframes.
Check it out to make sure it is not serious but expect it to be a cosmetic issue. Worth sorting out when if you buy the car to get rid of the advisories.
I’d be more worried about wherelse it may be corroded. (Like sills , brake pipes, suspension mounts, jacking points) As it could be very expensive to get these sorted.
How old is the one you are looking at? These things get worse, not better
you really need to get it on a ramp, peeel back the wheel arch liners and have a good prod.
