Hi everyone these are the detail for this years trip to the dales
This run will 113 pleasurable mile with good stopping point (and NO sheep fair!!!)
The start point will be the Craven Heifer pub just north of Skipton off the A65 10.30 for a 11.00 start Craven Heifer Inn, Grassington Road, Skipton, Nth Yorks, BD23 3LA http://www.cravenhei…co.uk/index.cfm
The first stop will be The Tan Hill Inn should be about 1h15 driving time the route will be via Hawes and J.Clarksons best bit of Uk road The Buttertubs pass we will stop for about 30 Mins and depart at @12.45 Tan Hill, Reeth, Richmond, Swaledale, North Yorkshire Dales, DL11 6ED http://www.tanhillinn.co.uk/
The route will be Via the Redmire moor and Back roads
The Main stop will be Masham at the Black sheep factory we will stop for about 1h30 and depart @ 15.15 The Black Sheep Brewery, Wellgarth, Masham, Ripon, HG4 4EN http://www.blacksheepbrewery.co.uk/
Route back will be Via Brimham rocks + Burnsal We should arrive back at the Craven Heifer at @16.15
Its a long way to the start point ,But can be done via the M65 + A56 from Manchester in an hour and Liverpool in 1h30 Even sheffield is only a 1h40h
Route maps will be provided on the day.Tom TOM itineries to be used with TYRE can be emailed out if required.
Paul Or Syd you can use this info for the Seperate website as well
Long time no see mate, mind if I pop over to join you all at Masham for lunch with my good lady? We might then follow on down to Brimham before turning left for home…
