Clearly my little car has been taking lessons of David Copperfield. I fill up the expansion tank the next day it’s empty, no sign of where it’s gone, it’s just not there anymore!
To give you some background in October I fitted a new radiator as the old one had cracked along the top which was fair enough in a car this age, anyway no problems changing it and watched the water level like a hawk for about a week and it didn’t move an inch. All good.
Anyway fast forward to last wednesday, I’m driving the car into work and it’s taking a long time to blow hot air through the vents, which in this weather you notice kind of fast. So i look at the temp and it’s looking a bit higher then normal as in not in it’s usual place ie a bit before halfway but a bit further along, well i had been revving a bit hard in very stop multiple traffic light induced traffic, so didn’t think too much about it as it seemed to go down again and I was cutting it some slack anyway due to the weather. On the way home things got a bit more serious the temps were randomly shooting up then settling back down, and then at one point shot up got dangerously close to max and stayed there. Panicking as you do I pulled into a car park gave it some time to cool down and looked in the expansion tank. Empty, right so that explains it I thought, and silently berated myself. Luckily I still had some deionied water from the previous radiator change sitting in the boot, so I poured that in the expansion and then drove slowly to a nearby homebase (only place still open at that time) and picked up some more deionised water. Topped the tank off thinking right so that should it. Well it did sort of, temps on the way home where a bit better and when i got home I topped the tank off again and revved it for a while (obviously it was drawing the water so I wasn’t worried). Then in the morning filled up the tank again as it was nearly empty (I hadn’t done this after revving it, as it was wet and raining), again I dismissed it as the car drawing the water in when I was revving it. Drove it into work and the temp needle did not move, big sigh of relief. Drove it home again and it didn’t move big sigh of relief again, then I checked the water in the tank… empty. Kicking myself again because I must have let it go so low for it to need that much water I poured another bottle into the tank (yes I overfilled it) thinking that should do it. At this point it had ‘drank’ a litre and a half of water, and had another liter in the tank. Anyway drove into work again this morning and again temps did not move but I just checked the tank on my lunch break (no time to check this morning) and it’s empty. Now seriously it can’t have drank a whole 2.5 litres of water, I think it holds about 5-6 anyway. So where is it going? Under the car is bone dry, and so is the engine bay.
(in case any of the astute readers are worrying about antifreeze levels by the way when I changed the radiator in October I put in a 50/50 antifreeze mix so seeing as 25/75 I’ve been told is fine I’m just I think diluting down the excess, not leaving it without anti-freeze entirely)
I’ve looked around and there is absolutely no sign at all of a water leak anywhere, and I’ve checked the oil dipstick and it’s clean also the car is running fine and not smoking popping etc etc so I don’t think head gasket.
Unfortunately what I haven’t been able to do is take the radiator cap off as the car has been hot each time I’ve had to check it, thats a job for this weekend.
Anyway I’m going to go over it with a fine tooth comb tomorrow but thought I’d open this up to see if anyone had any suggestions of things to check.
Thanks in advance, and sorry for the ‘essay’
i have hit this one before on an owers car,arn’t they great
