The frozen windscreen 18p hack to clear icy windows in seconds
You’re in a rush and you’ve just found all the windows on your car are frozen up. A nightmare start to your frosty Monday morning - or any morning in your week for that matter - unless you work from home of course.
Well, help is at hand because if you have just downed your coffee, or morning cuppa of the old faithful Yorkshire Tea, then run back to the kitchen and pop some cooling kettle water in those freezer bags you never use - and then rub the bag over your windscreen and windows. Job done.
The hack - which if you buy 15 of them from Tesco in an XL box then you’re on your way for it to just cost you 18p in the £2.75 pack - has proven a hit with all motorists without damaging your car at the same time.
The key to the viral video showing you how it’s done is to make sure you have some cold water in the bag to start with to make sure the bag doesn’t contain boiler water that it splits and scolds you - and probably sending you to A&E on foot.
My de-icer always lasted for years until I bought a 12-inch tall can of Good Year Fast Acting De Icer only last week.
It’s fast acting alright. It only lasted three days.
I’m experimenting with 70% alcohol surgical spirit with a dash of Star Drops.
I’ve tried the water-in-a-bag technique using a Kool Pak I keep in the fridge for back pain and grand kid’s bumps and bruises. They work pretty well and can be microwaved.
Plastic sheet, cut to windscreen size and trapped in both doors the night before.
Clear screen without fail, even in minus 5…
Quick scrape of side windows and heated rear screen on, job done.
I use the old skool recycle old news papers method. Place a couple of sheets beneath the wiper blades, stopped halfway through sweep, across the screen the night before.
Here we all are, telling each other how to clear frost off our windscreens, when most of us were able to do this before we passed our driving tests.
1975 in a Mark 2 Escort in my case.
Many years ago I had an Impreza that I could start remotely with the fob. If I knew it was going to freeze I’d put the A/C on and turn the fan to full before I left the car the night before. Then I’d start the car with the fob the following morning and it would warm up and defrost nicely. It had security features so that the car couldn’t be driven unless it was then unlocked with the fob.
I must thank my neighbour for covering my windscreen during the frosty evenings, I got up to go to work to find my screen covered to protect it from frost, so tar pauline
