Downloadable PDF’s of the routes used can now be found at -
http://www.mx5oc.co.uk/forum/files/folders/run_details/default.aspx
The Dark Peak is the northern area taking in the Gritstone Edges and The Hope Valley,The <st1:place w:st=“on”><st1:placename w:st=“on”>White</st1:placename> <st1:placetype w:st=“on”>Peak</st1:placetype></st1:place> is more on the Limestone area, and includes an old rail tunnel, inside which you can act like a big kid and toot your horn,
The runs were plotted on miles, and the kilometers are a conversion, so bear with me if the kilometers are very slightly out.<o:p></o:p>
If you fancy a splash, the Tissington Ford has now re opened by now, have a look at in on the map, turn left before the turn into Tissington village, signed Alsop and Parwich, left at the T then left to Tissington, via the ford, re start the route with the coffee stop on your right.
<o:p><v:shapetype coordsize=“21600,21600” o:spt=“75” o:preferrelative=“t” path=“m@4@5l@4@11@9@11@9@5xe” filled=“f” stroked=“f” id="_x0000_t75"> UPDATE for SEPTEMBER and early OCTOBER</v:shapetype></o:p>
<o:p><v:shapetype coordsize=“21600,21600” o:spt=“75” o:preferrelative=“t” path=“m@4@5l@4@11@9@11@9@5xe” filled=“f” stroked=“f”></v:shapetype></o:p>
<o:p> </o:p>
