Thread size battery terminal clamp ND
  1. My model of MX-5 is: __ND
  2. I’m based near: __PETERBOROUGH
Anyone know what size the thread is on the battery terminal clamps, thought it was M6 - right diameter but not an M6 thread. Could it be M6 fine?
M6 x 1.0 as far as I know. The bolt might have a burred end to stop the original nut coming off though.
Thank you :+1:
I checked today and it seems that it does. If you crack if off then unscrew it with your fingers it stops at the end of the thread.
Thanks for the info, much appreciated. :+1:
