Ticking noise from central locking?
Hi, after replacing the little triangular window on my NC 3.5 (2010 2.0 PRHT) i have every now and then a ticking sound which seems to come from the central locking…only occurs when opening doors and sometimes when locking<:unlocking . It’s very subtle and dies after a few secs. Central locking works normally. Ticking also seems to come from the right side while the window was replaced on the left side. Al connectors are …connected.
Ticking comes from both sides and only when a door is opened.
Solved…after re moving the door pannel i found the central locking connector not pushed back enough …did that and problem solved.
