I am looking for the tool to undo the bolts to access the the big end bearings, does anyone know where I can get one? My MX5 MK3 2009.
From memory are they not a 12 sided 12 or 14mm socket?
Yes, external Torx.
Yes E12, have now now removed. Found big end No. 4 bearing is the problem looks like it has spun in seating and one on top of the other slightly. May have done damage to crankshaft will know better when I clock it.
I was reading a strip down of an engine and twelve point was mentioned I’m sure. Is it possible they changed the fastener overtime? Just a thought.
