My 1995 mk1 MX-5 (Eunos) went in for its MOT this week, and failed on emissions.
A forum member mentioned to check that it was tested as an import - which I did, and it passed. A little bit of knowledge that saved me a small fortune in garage bills!
Just in case anyone is in a similar position, as I understand it this is how things work…
- For an MX-5 the MOT emissions level for CO2 is 0.3 - in my case the CO2 was 1.2.
- As the Eunos is an import, it’s unlisted in the offical MOT manual, and so it gets an MOT emissions level of 3.5.
It seems that not all garages know about this, or you need to point in out in case they miss it.
I think the tip to bear in mind is that not all MoT testers are MX5 spotters, and couldn’t tell the difference between an MX5 and a Eunos if it ran over them. So when the machine says ‘what car is this?’ he’s probably going to guess at MX5 first off. Sure, if he looked closely he’d see the badges, if he knows what they mean, but with 10 cars to do today and 50 this week, he probably won’t.
So if you have a (fairly) unusual, imported, but pretty much identical version of a UK car, don’t assume that the tester knows as much…tell him first, then he won’t have to waste his time and yours on doing the wrong test.
I disagree, a Roadster in a good state of repair will still pass a UK emission test.
EGR is to reduce NOx which is not measured on an MOT so has no bearing on the result. EGR wouldn’t be operating at fast idle ayway. The ECU would still be mapped to run the engine stociometrically at fast idle so the catalyst is working at it’s optimum.
A short cat on a 1.8 is very marginal, that is why bigger cats were introduced
A 1.8 with a good short cat will JUST scrape through ( my Cal runs a short cat) but the cat needs to be hot.
Problem with a lot of MOT is that the car is looked at before emissionsare tested. Where as if it fails on only emissions these are tested straight away when it arrives hot on the retest
