hi, this weekend I’m planning on replacing discs and pads on my mk3, but i can only find settings for older models online. ideally i need the calliper and bracket bolt torque settings.
all i can find is : foot-pounds / Nm
| Front/rear bracket bolts |
36-51/49-69 |
58-65/78-88 25-29/34-39 |
| Front/rear banjo bolts |
16-22/22-29 |
| Rear adjuster plug bolt |
9-12/12-16 |
are these correct?
Front bracket to front hub upright
58 to 75 ibft 78 to 102 NM
Rear bracket to rear hub upright
36 to 51 lbft 49 to 69 NM
Front caliper to bracket smaller bolt than above.
16 to 23 lbft 22 to 31 NM
Rear caliper to bracket smaller bolt than above.
15 to 18 lbft 20 to 25 NM
Brake Hose Banjo Front
Brake Hose Banjo Rear
16 to 22 lbft 22 to 29 NM
The rear calipers require that the piston is wound into the caliper not pushed in but any I have done move easily and a wide screwdriver will do it but a caliper wind back tool is nice to have
