Hi,
I have Toyo Proxes fitted atm and need to get the front two replaced (poss back also) soon as they’ve been wearing on the outer side and need aligning… :-/
I’m trying to figure out the exact tyre type… There’s a code PXT1R -1 on the tyre near the size… am I right in thinking this is the same as T1R I’ve seen mentioned on the forum?
The size is 205/50 ZR 16 87W if that helps.
Thanks folks
Would assume so, this is what they look like…
anyone got an idea what these tyres above,would cost please
If you go the website shown below put in your number plate and the site will tell you your tyre size and then give you prices of various tyres suitable for your MX5.
www.tyre-shopper.co.uk
Thanks martin - I mustn’t have looked properly the first time because they do indeed say T1R, as on the image above!
leemarb - they have them on camskill for £66.28 each.
Last time I was at the Mazda garage they said they’d match the price when I said I could source them myself cheaper… whether they’ll stick to that though I don’t know… worth a shot!
Cheers folks.
Hi
When I replaced mine it was £130.00 the pair. That was 6 months ago so the price you are seeing is about right. 195’s rather than 205’s would be a few quid cheaper!
Regards Julian
