Final Instructions
Dear Mallory Drivers, please find final instructions for the day. You may receive this massage more than once if you have booked more than one session <o:p></o:p>
<o:p> </o:p>
Mazda on Track Master Contact Number 07966 332292<o:p></o:p>
Please put this into your mobile phone, it will be active from 7:30 to 17:30 on Saturday.<o:p></o:p>
<o:p> </o:p>
<o:p> </o:p>
Arrival time<o:p></o:p>
Entry to the track for track driving is from the Paddock. However, the access to the Paddock for vehicles is across the track, therefore during track operation there is no movement between outfield and Paddock.<o:p></o:p>
Therefore it is important that you arrive at he correct times to get access to the Paddock for your session.<o:p></o:p>
<o:p> </o:p>
There will be a marked parking area at the opposite end of the Paddock to where you enter, please proceed to this area and park in the appropriate space. <o:p></o:p>
<o:p> </o:p>
Morning sessions. <o:p></o:p>
Access will be from 7:30 onwards. Access will close at approximately 8:50<o:p></o:p>
Driver and passenger sign on will be from 7:30. This will be in the signing on room under the Race Control Tower<o:p></o:p>
Driver briefing will be at 8:30 in the briefing room under the Race Control Tower. <o:p></o:p>
Important. You will not be allowed on track without attending the whole of the drivers briefing. The briefing room doors will be locked during the briefing and so if you are late you will not get in and you will not receive a briefing wrist band, and therefore there will be no track access. <o:p></o:p>
Do not be late!<o:p></o:p>
<o:p> </o:p>
If for what ever reason you have not managed to arrive at Mallory before the access route is closed please phone the MoT Master Contact Number and tell us your expected arrival time. <o:p></o:p>
If this fits conveniently with the current activity on track we will attempt a very short track closure to allow cars to cross. There will also be a second safety briefing at 9:45 allowing late arrivals to go on track some time after 10:00. Drivers arriving after this time will not be permitted on track and their morning track time will be forfeit. Late drivers may be able to purchase afternoon time if slots are available. <o:p></o:p>
<o:p> </o:p>
Afternoon sessions<o:p></o:p>
Afternoon cars are welcome to arrive before 8:50 and be left in the Paddock all day, however assuming you would rather have a lie in, then cars should be brought to the Paddock, via the upper car park (the area with the statues when you arrived at Mallory). The track will be closed until 12:30 due to track activity. It will close again at 13:20<o:p></o:p>
You will not be granted access to the Paddock unless you have either a track access sticker from Mazda on Track or your correct activity ticket. <o:p></o:p>
You may queue ahead of time in the upper car park.<o:p></o:p>
You may sign on at any point throughout the morning and if you do so you will be give the appropriate window sticker that allows you access to the Paddock.<o:p></o:p>
<o:p> </o:p>
<o:p> </o:p>
Latest Sign on times are <o:p></o:p>
Red Sessions 12:45<o:p></o:p>
Blue Sessions 13:45<o:p></o:p>
Green Sessions 14:45<o:p></o:p>
<o:p> </o:p>
Briefing sessions will be:<o:p></o:p>
Red Sessions 13:00<o:p></o:p>
Blue Sessions 14:00<o:p></o:p>
Green Sessions 15:00<o:p></o:p>
<o:p> </o:p>
Driver briefing will be in the briefing room under the Race Control Tower. <o:p></o:p>
<o:p> </o:p>
At approximately 14:10, 15:10 and 16:10 there will be a short stoppage during which time cars may enter or leave the Paddock <o:p></o:p>
Cars wishing to enter should queue at the top entrance car park<o:p></o:p>
Cars wishing to leave should queue at the top of the Paddock. There is a sign indicating where they should queue. <o:p></o:p>
<o:p> </o:p>
Drivers leaving or entering should drive on the left as they would on the road.<o:p></o:p>
Drivers should not dawdle, but also should not use excessive speed. <o:p></o:p>
Use their Hazard Lights while on the circuit to show that cars are on track under open conditions.<o:p></o:p>
Be aware that cars will bunch at exit gate to the circuit and that you are entering an area where pedestrians could be. <o:p></o:p>
<o:p> </o:p>
Tuition<o:p></o:p>
<o:p> </o:p>
Additional Tuition slots will be available throughout the day at a cost of £25. If you wish tuition please book this at the signing on desk. <o:p></o:p>
<o:p> </o:p>
<o:p> </o:p>
Petrol<o:p></o:p>
<o:p> </o:p>
Mallory’s own fuel station will be open during the day. It is situated at the top of the Paddock. It will be more than regular pump prices therefore it is recommended that cars are fuel prior to arriving at Mallory. There are several fuel stations within 5 miles of the venue.<o:p></o:p>
Running out of fuel on circuit is a bad thing. It will cause the session to be stopped while your car is recovered and people will hate you. Please ensure you have enough fuel for your track time.<o:p></o:p>
As a rough guide you will use 2 gallons per 20 minute session. If you have a turbo monster, then you will use more. <o:p></o:p>
<o:p> </o:p>
Seatbelts<o:p></o:p>
<o:p> </o:p>
Seat belts and helmets must be worn at all times by driver and passenger when on track. We strongly recommend that both arms and legs be covered as well. <o:p></o:p>
If any driver has an aero screen car, full face helmets must be worn.<o:p></o:p>
Mazda on Track has a supply of about 20 helmets for hire on the day at a cost of £10. On a first come, first served basis. <o:p></o:p>
<o:p> </o:p>
Brakes / Tyres<o:p></o:p>
<o:p> </o:p>
Prior to arriving please inspect the brakes and tyres of your car to see there is sufficient life in them for the track. Morning session drivers will require pads / tyres to be no more than half worn. Afternoon session drivers should allow 1mm per session. Please also check the level of your brake fluid and top up as appropriate.<o:p></o:p>
Mazda on track will have a limited supply of EBC Yellow Stuff High Performance Brake pads for purchase on the day. Please let us know by the end of Thursday if you wish us to bring replacement pads for you including MK3 cars. <o:p></o:p>
<o:p> </o:p>
General Mechanical condition<o:p></o:p>
<o:p> </o:p>
Track driving will in general place a greater stress on your car than normal road driving. It is important that you prepare your car for track use. Check your fluid levels. Ensure you have sufficient oil in your engine. If you are doing both morning and afternoon sessions check your oil level between the sessions, the same goes for coolant levels. <o:p></o:p>
Take great car checking a hot engine to but burn or scald yourself. <o:p></o:p>
Also inspect your coolant hoses and belts. If they are on the way out, change them, the track is not the place you want them to burst or break.<o:p></o:p>
Finally inspect the general mechanical condition of your car ensure nothing is loose, broken or leaking. <o:p></o:p>
<o:p> </o:p>
Take time to warm your car on track, do not go flat out on your first lap, equally after the chequered flag slow to half your track speed and allow your car to cool as you come into the Paddock. <o:p></o:p>
Do not turn your engine straight off, especially if you have a turbo car, but allow the car a minute to circulate coolant to cool. <o:p></o:p>
Do not apply the hand brake, but rather turn the engine off and leave the car in gear, this will avoid the risk of the hand brake sticking to the hot brake discs and also prevent warping of discs. <o:p></o:p>
However, do remember the car is in gear when you go to start again.<o:p></o:p>
<o:p> </o:p>
Hot Laps<o:p></o:p>
<o:p> </o:p>
Ladies, please be aware that Hot Lap cars will have race Harnesses which will include a crotch strap. We recommend that you wear trousers. If you wear a skirt it will require to be hitched up, which may cause embarrassment. It will however make your driver very happy.
<o:p></o:p>
Towing eyes.<o:p></o:p>
<o:p> </o:p>
If your car has screw in towing eyes, (MK3 Owners) please insure they are fitted to your car once you arrive in the Paddock. It should be fitted to the front of the car if there is only one. st1:cityst1:placeMarshalls</st1:place></st1:city> are under instructions to remove broken cars expediently from the circuit. If there is no obvious towing point they are apt to wrap tow ropes and straps around any convenient part of the car.<o:p></o:p>
<o:p> </o:p>
Items in your car.<o:p></o:p>
<o:p> </o:p>
Please remove all unnecessary items from your car before going on track. It is not necessary to remove spare wheels but loose items that will fly around the car during spirited cornering. We will provide an area where items can be left but it will not be secure so please consider the value of any items you wish to leave.<o:p></o:p>
<o:p> </o:p>
MK1 Owners, please check the security of your battery clamp. If your battery is loose you may we receive a “battery escape hatch” dent in your rear wing as the battery makes a bid for freedom.
<o:p><o:p></o:p></o:p>
