Hi there, can anyone recommend an independent garage to look at a knocking/rumble in the rear when going over bumps and potholes? A local garage diagnosed "play in the off side lower bush"- he does not have the tool required to take off the hub.
With my previous two MX5s I used a brilliant local guy but he has retired, I tried one recommendation in Nuneaton but got no response, another does not do this kind of work and the third has some worrying reviews.
Iām in Birmingham but happy to travel 40 miles or so, any info would be much appreciated.
It sounds like the known issue of spherical bearing/bush wear, I donāt know the geography of your area, if you can get to Roddisons in Sheffield he will sort it for you. @rodders
Looked it up, probably double the 40 miles but well worth the trip.
It isnāt necessary to remove the hub, lookup Andy Leslie on facebook, he makes and sells replacement bushes with a fitting tool that allows replacement with the hub still on the car that any independent garage can use.
Thanks Gareth, I will explore that option also, although the mechanic did say he could buy a tool but around £300 and may not use it again but hopefully I have some time to sort this out as mileage now is minimal.
Hi, Only just seen this, thanks for the recommendation, I still havenāt got it sorted and now heading for MOT, service & other issues appearing so preparing myself for a big bill! This is the first car I have bought from a garage and had an AA āinspectionā on and the last time I will do either.
