- My model of MX-5 is: NBFL 1.8VVt
- I’m based near: Chesterfield__
Hi all. Just looking for ideas on what could be causing the trigger offset needing to be set 10° off what it normally is with a 36-2 trigger wheel. I’m part way through tuning my car with Alex Hickson. He says the trigger offset with that trigger wheel is normally 559 but I have to have mine running at 549 for the car to be running smoothly and 539 for the timing marks to line up when fixed fire mode is on. When at 539 the car does not run or drive well with fixed fire turned off.
I’ve found TDC with a screwdriver in cylinder 1 and put a new mark on the crank pulley and there is a 10° difference between that and the original marks on the pulley. Could it be that the crank timing belt pulley is a tooth out?
