Turbulence
I picked up my nice shiny mk2 on Saturday, and while trundling down the motorway on the way home (roof down, of course!) I was having a play around with the bits I could reach. One thing I noticed, when I dropped the windows, the car suddenly felt a lot more twitchy, as if it was getting caught in a crosswind, or similar. When I put the windows back up, it went back to normal. I was wondering if this was likely to be caused by the wind catching on the style bar :
It’s fairly chunky!
I was going pretty quickly when this happened - motorway speeds - so I’m guessing it was the wind catching on the car. Does anyone else have experience of these bars causing this?
The other thing is the car has a wind blocker (you can just see the hinges for it behind the headrests) which flips up and against the back of the style bar. I put it up to see what it was like, promptly forgot about it and then left the roof up for a very short trip. Heard a rattling noise, got rather worried, then realised it was the wind blocker banging against the style bar. Is this because I had the roof up? In normal driving, I guess it would be held against the bar by the wind…
 Apologies if these are dumb questions - obviously I’m very new to the car and still learning about it!
 Well you seem chuffed to bits!
Top down I tend to lower drivers window - sounds daft but it reduces driver turbulence.
Can’t comment on wind blocker as I can’t fit one with Hard Dog cage (could fit permanent perspex, but not really that bothered).
Rattle - might be worth finding contact points and using a sticky felt pad or something to cure it - or just put wind blocker down! [;)]
When I have roof down it saves me £s - I tend to drive slower… [A]
 I’m very happy indeed with it! I went outside earlier to move it from in front of my work building into the car park at the side, a drive of maybe 500 metres, and even that put a smile on my face. It’s fantastic.  :smiley:
I’ve got electric windows, controlled from the centre console, so it’s easy enough to drop both windows, so (to hint back at the OCD thread in the Other Car Stuff forum) I think I’d do that to keep the symmetry! I’ll try only lowering one though, next time I hit motorways. Was just wondering if anyone else had found their cars getting twitchy like that. I’m not too bothered about the wind blocker - as you said, it’s hardly essential - but the twitchy feeling bothered me a bit.
I’m going to have to remember that about the roof down saving money for next time the other half complains about me wanting to motor topless!
 I’d check your tyre pressures - these like to be at around 26psi ~ I run at 30psi on Toyos as they have a softer wall apparently.
Maybe it’s just a case of getting used to it - after Mrs Goof has been wallowing around in her Modeo Ghia X for 2 months, she now dislikes the silly red car… shakes her t*ts off apparently! [;)]
A visit to Wheels In Motion is worthwhile - approx £100 for a fast-road setup from the geometry guru…!
 True, I’ve not checked the tyres - probably should do! It came with Toyos, so I guess I should play at 30 too! The twitchiness was definitely when I lowered the windows, and went away when I raised them, so I think it has to be something to do with the airflow. The car’s already been to WiM, the previous owner seems to have been taking very good care of it!
I think I just need to let her drive it - I’m sure she won’t be able to criticise then! At least, I hope not…  ¬_¬  But the problem with that is that it cuts into my valuable driving time!
