Everything else including the Nuts/Bolts/Rubbers and other couple fittings I can’t seem to find
Also, since I am not mechanically minded, I am unsure as to what part the engine is labelled in green. I have saw this re-painted etc with some nice work being done and I am looking to get ideas. For example:
I’d be inclined to grind away any rust on the brackets and paint myself. Ok if you can buy new, not much money.
The part indicated in green is a cam cover. Some owners paint there own with the appropriate paint or even buff them up to get that polished aluminium look.
Takes a good deal of prep for paint or buffing.
I once did the panel in front of the radiator and the manifold cover (buffed them) looked good.
My camcover looked like that and I removed the furring with Raceglaze Alubright Oxidation Remover. OK, it’s not a polished finish, but it’s back to nice clean alloy.
Just be careful where it goes and rinse it off carefully.
