Can anybody advise me as to which seal fits inlet and exhaust. There are 8 grey and 8 green in the set but no information provided. I have googled it but I get conflicting information.
Apparently the inlet seal has one ridge on top whereas the exhaust has 2 ridges - make sense?, I hope so but perhaps only applies to OEM parts.
Black/grey for inlet and green for exhaust.
Exhaust requires viton or similar for heat protection, inlet does not. Aftermarket often makes these generic to exhaust spec to save confusion…or that is the theory.
Thanks for the information but now I’m more confused than ever, close inspection seems to show identical design apart from the colour and the grey one alarmingly has a slightly bigger diameter hole for the valve stem although both valves have identical size stems. I’m thinking of binning the lot and buying some more ! Any thoughts ?
