I have RH light that mists up when 1994 car washed.
Does anyone have good condition pair of lights in good condition to sell that dont mist up?.
Be sure that it is the sidelight/indicator unit itself that is to blame.
The usual culprit on these is the little loom. The sidelight connector lugs break and it loses seal.
Can be repaired by soldering on a replacement connector; I have some of these.
Usual culprit is the connectors at the rear have broken and don’t seal THIS PART required
thank you both…I will keep an eye on the bulb holder, which hasnt broken, yet!
but is the o-ring seal in place?
it is…![]()
