Just bought a MK3 MX5 does anyone know how to adjust the washer jets - the drivers side needs raising up but the old needle down the jet to move it doesn`t appear to work on these jets.
Del.
Del.
Hi,
Did you manage to work it out? I’ve got the same problem.
cheers
Bit of WD40 and waggle two minutes later
There is no adjustment procedure listed in the workshop manual for the NC so I would guess that by design, they are not adjustable.
Thanks for the replies. They currently point straight at the wipers so I can’t imagine that’s factory set. Once I’ve dug the car out of the snow I’ll have try another look.
It seems the adjustment is the same as normal ie. a needle down the jet - mine was well seized but I managed to adjust it after a drop of anti seize and gentle persuasion.
Del.
