Water drains
Just purchased a 2006 model but struggling to clear the water drains…it’s driving me crackers…any tips please
Here’s a starting point:
Is there not a valve that only goes o e way, not even sure where the hole is from underneath :joy:
There is a one way flap at the bottom of the drain that if pulled up can create a resonance in the cabin that you don’t want. The drains flow out inboard of the cills, a look at the link I posted will show pictures and offer lots of previous experience on the matter.
quickest way is take them out, about 20 mins a side, small screw driver 10 and 14mm socket. check out you tube its pretty easy seat belt reels need to come out
My flaps are missing
Without the flaps, noise levels are very high. Stick a bit of sponge in the exit hole, that will keep things quiet
I have done
Hot soapy water down the drains works a treat.
Seems to unclog the valves too
Sorted, thanks. Lovely see water pour out underneath !!
