Hi my 2010 mx5, has fluid dripping from behind front passenger side wheel, it’s dripping out of the rear wheel liner . Looks clear like water… did have heater blowing. Is this normal or time to take off the wheel liner and go digging?
TIA
TIA
Chances are it is the aircon. It is the right place if using the aircon to speed up demist.
If you’ve been doing some demisting in a slightly damp cold car this happens!
I’ve also been told in the past, that this can happen if you’ve been using the aircon with the roof off - as you’re inadvertently attempting to air condition the whole planet !
Thank both. It’s almost certainly just water based on appearance. I did have roof down and heater on. I’ve seen plenty cars do similar when air on is running, but can running the heater causer the same?
