WATERLESS WASH, SHINE & PROTECT
I found this site when browsing various sites in the U.S. as I was on the look-out for sequential rear indicator mods (found it on Amazon.com, but that is a different post).All I can say is that this stuff is amazing. I washed the car very carefully, snow-foamed then hand washed (two bucket method) and then applied this as a top coat. You use a damp microfiber cloth to apply approx 3’ x 3’ and then buff off with a dry microfiber cloth immediately. I did the glass as well.
In all of this rain, a quick drive home from the Eastern Meet tonight and all of the water literally blew off the bodywork - it is VERY slippery!
Not cheap, but one bottle should last at least four applications using it as a “finish” after a normal wash.
INFO
FORTIFY QUICK COAT is the most scientifically advanced 3-in-1 Ceramic Waterless Wash, Shine and Protect formula. This long-lasting and extremely durable product is designed for vehicles and other solid surfaces that require a superior shine and protection. This DIY/ at-home detailing product is a perfect blend of soaps, surfactants and wetting agents, plus a superior Si02 ceramic protective coating.
Laboratory-Engineered and tested by Professional Detailers from around the world. No other silica sealant can actually clean, seal and protect at the same time. Fortify does!
ONE APPLICATION DOES IT ALL – CLEANS, SEALS, PROTECTS
Our FORTIFY formulation team developed the ONLY DIY, at-home detailing product that uses waterless cleaning technology and wetting agents to gently, safely and effectively cut through dirt, grease and grime on-contact – leaving you with a clean, sealed and protected surface each and every time.
