Waxoyled
 I am thinking of getting my 2004 car Waxoyled in the next couple of weeks. Any pros or cons to having this done. Many thanks
Hi Silver, Yep will be having mine done this month.
Pros - helps reduce rusting from the inside if professional injected into sill, doors, chassis members etc. Coats nuts and bolts helps them from seizing. Can protect suspension components if done, I wont have this done though. Adds value to the car. Improves appearance.
Cons- Mucky job if doing it yourself. Can be messy when working on the underside. Some areas my require touching up after a couple of years.
Best waxoyl specialist is - http://www.rustmaster.co.uk/  £350.00
Or in my opinion a better option is - http://www.dinitrol.co.uk/?gclid=CKXx3Kv0yJkCFQZqswodKG8mug
Best dinitrol expert is - http://www.chassisclean.co.uk/
Mozza
 Cheers Mozza, some good info there, let me know how you get on
Andy
