Weak brake assist on MK1 1.6
Hi
I have just bought a ā€˜89 MK1 1.6 and in my opinion there doesnā€˜t seem to be much power assistance in the brakes. Ā You have to press really hard and the pedal feels hard (it does not have that slightly spongy feel that power assist normally adds).Ā
Is this normal? Am I just too used to modern cars with loads of assist?
I’ve not yet taken the vacuum hose off to check there’s proper vacuum. The brakes work fine as such. They don’t seem to bind and the car stay dead straight during braking from any speed. But you really have to brake hard and you can just about lock the wheels up if you REALLY push it (No ABS).Ā
Some guidance from more experienced owners is very welcome.Ā
Try pressing the brake pedal with the car in neutral and the engine stopped (no inlet vacuum). Then without easing off the brake pedal, start the engine. The feel of the pedal should change; it should move down slightly. If not, the servo or pipework might be faulty.
Ah yes of course! thanks Paul, I will try that. It’s been such a long time since I drove an honest, analogue car. Been cocooned for too long in these modern hybrids.
Funny you should bring this up Pixies.
We have 2 5’s, a 2002 Sport & my '93NA…which also is an Auto.
We have had them both for nearly 16 years , and have no issue through years of habit with either’s ā€œfirm applicationā€ of brakes…the Sport more so than mine.
However, I’m also insured to drive my son’s 2014 plate Fiesta, and suffice to say it takes a few miles to acclimatise to the fact if I use the same amount of braking force…were it not for the seat belt my incisors would embed themselves in the steering wheel…the same with an elderly neighbour’s newish Pug which they entrust me with to ā€œloosen upā€ now and then as they do not use it much.Ā
However, you’ve been given a possible check/solution…so…good luck with that.Ā  Ā Ā
OK - so I’ve had a quick look today…
  • While depressed, the pedal does go down a little bit when starting the engine > good sign
  • checked vacuum at the brake servo and get a steady reading of 47-48 cmHg > spot on
  • Tried braking with vacuum disconnected and then reconnected. There is definitely a big difference.
I can only conclude that this is a combination of me not being used to the car and a rather modest assist.
We have vacuum!
That said, until I’ve gone over the brakes and exercised the pistons at each wheel and replaced the brake fluid with new ditto, I will still not be entirely convinced. I did notice that the main cylinder is ā€˜sweating’ somewhat. There even appears to be a thin thin layer of fluid below the cylinder. Is this a common age related ailment? I’ve not seen any master cylinder gasket refurb kits. Buying a new was horrendously expensive.Ā
Seeping!
I will clean off everything so I can hopefully get a sense for the rate of seeping and where it comes from. I kept things dirty for the photos so I have a record of what it looked like.Ā
Ā
/P.
Hiya, looking at the last picture, the slight amount of fluid showing may just be spillage from when the resevoir has been topped up? As you said, clean it off and monitor the situation.
I like your thinking. That is a good point.
If you let us know where in the world you are, a local fellow owner may be able to pop round and give your pedal an objective feel.Ā  So to speak.
Steve
Hey Steve, that’s what I was thinking too. I’m in Northampton. If anyone wants to pop by send me a PM.
As this is a 30 year old car that’s brand new to me, there’s a bit of a learning curve :slight_smile:
Sounds like you have checked everything and in all probability , like others have said , brake efficiency has evolved significantly over 30 years causing the noticeable difference vs your modern ā€˜daily’ . I certainly treat the pedal on my big 6 month old barge with a degree of ā€˜tenderness’ compared to the Mk1.Ā  One thing I did find that seemed to firm matters up on the Mazda (mine’s only 28 ) was the fitment of Hel Braided flexi hoses . Worth a try if you are still in need of improved retardation so to speak !Ā
Pixies
Before you go any further you need to make sure what you have is working properly as you have suggested.
Strip each brake in turn.
Replace any rear disc that is under 7mm thick and front disc that is under 16mm in thickness. This assumes that 1600 cc brakes are used.
I tend to replace disc pads with around 7mm thickness, others will say the disc pads will last longer.
Make sure that red rubber grease is used in the slider pins rubber socket interface, not copperslip and that any metal to metal sliding surfaces are lightly covered not too much with ceramic grease.
Over the years the operating mechanisms can go out of adjustment and the mellens.com workshop manuals give guidance on making brake pedal adjustments, testing the ā€œBrake Boosterā€ and adjusting the ā€œbrake boosterā€ master cylinder clearances.
In my experience once all this work is done the braking system will be quite impressive.
Another possibility is that the brake surfaces have become ā€œglazedā€, both discs and pads polished up to gloss and just skating over.Ā  This can happen when a car is driven too gently…
Years ago I bought a car with seemingly duff brakes despite a working servo (tested as above), and on the way home they only began to work properly after a major panic stop when the motorway ahead suddenly became a sea of red brake lights.Ā  With that car (FE Victor Estate) I put the discs on the lathe and scrubbed off the glossy surfaces with an emery pad and also put new brake pads in.Ā  After that it was superb.
With my NC more recently the rear discs became so rusted by a couple of weeks parked at Gatwick they did almost nothing, and a skim/clean up and new pads again made an enormous difference.Ā  I hadn’t realised quite how much the NC rear brakes did until being able to compare how well the car sat with brakes working all round instead of pitching forward with only fronts effective.
Ā
Two thoughts.Ā  How old is the fluid (have you tested its water content)? If that’s okay have you bled the system.
Richard - you are right about glaze on the discs. The previous owner only did 300 km with the car in the last 12 months and about 1000 km over the past two years. So, yes, that’s nowhere near enough use. Particularly as it was kept outdoors (not good!). Even after the 60 mile journey to bring the car home and some additional ā€˜workout’ - the glaze was obvious when I took off the wheels to inspect…
FRH disc
I have since, tried to remove the glaze and rust with a rotating wire brush (working from centre out) and bled the brakes. Cylinders are moving freely all around. The fluid needs changing.
I also had an mx5 specialist test the car and got the verdict - ā€˜it’s fine.’.
Well so, it’s all good enough for now. It will be better once I decide to put new discs and pads on.
Thanks for all the tips and ideas.Ā
Ā
Unfortunately a wire brush isn’t really hard enough to remove the glaze, although a stainless steel bristled one will remove the surface rust. However, some disc pads have an abrasive coating, which is designed to ā€œbustā€ the glaze on the disc and bed them in quickly. I think one type I’ve fitted in the past were made by APEC. It might be worth fitting new discs, though, best not to take chances with brakes.
Just a quick response offering an alternative view. I personally don’t like the excessive servo assistance on my other cars (BMW Z4 & BMW Mini) and I do like the extra ā€˜feel’ I get from having to exert some of my own muscle. Either way, hope you get to where you are happy with your brakes; they are kinda important!
You are absolutely right. If I had a lathe I could remove a few 100th of a mm. Inevitably, new discs and pads will certainly be put on. The current discs have actually not done many miles and they are quite good as is. I’m satisfies, the pads sweep the whole surface and are effective. I’ve also flushed and replaced the fluid.
There is a problem with removing anything other than light rust from discs that the brake action itself should be capable of clearing.
The material/tools required will remove sufficient removal as to take a lot of brake action, particularly on the rears to get them right again and likely by that stage the original problem is back.
I have used aluminium oxide paper and thinking about it a well used flapper disc on a grinder would be a lot easier and quicker but probably require new pads with the top abrasive layer to bed in sufficiently quickly to be useful.
Looking at the picture, it is not easy to assess but on the face of it probably worth removing the disc and having a quick try to remove the glaze. As I am sure you are aware that glaze will be on both sides of the disc.Ā  Ā Ā
Brake discs and pads are so cheap. I seem to remember replacing all four corners on the Eunos 4 or so years ago with quality parts from various suppliers for around £50 all in delivered.
Hi everyone
Ā
Since we’re all here to learn from our joint experiences I thought I’d post a quick update on this thread.Ā
In short, the ā€˜problem’ with my brakes were, as many of you suspected, simply a case of glazing due to lack of use. In the two months that I’ve owned the car I’ve covered more distance than the previous owner did over the last two years! The issue becomes more apparent when you compare photos of one of the brake discs before and after.
Ā
Shortly after I bought the car - you can see plenty of dark areas of rust that has been ā€˜smushed’ down and polished by the pads to a lovely shine…
Glaced disc
And after about 1500km of ā€˜mixed’ driving - much of the rust has now worn off and fresh, grippy steel exposed…
healthier disc
The brakes now feel as I would expect from a car this age - perfectly adequate. The change has been very gradual but I can definitely tell the difference. I’m no longer having to retrain when moving between the Mazda and my modern daily driver.Ā
There are still some dark spots on the discs but they are small and will over time disappear. I’m just keeping an eye on disc and pad thickness but the discs clearly have not covered many miles since they were installed. Plenty of smile-miles to go!
Ā
Onwards!
Ā
