Guys, I thought I would share with you my welcome lighting project. It’s been fantastic day although I have dismantled the interior of my brand new
Anniversary MX5 to get there.
I made up a wiring loom, Connected one end to the internal light, ran the cable along the headliner down the A pillar on the driver’s side, then onto each footwell with a connector . The LED lighting strip was stuck with 3M tape to the footwell panelling.
When the interior light comes on so does the LED welcoming lights.
I bought all the bits off Amazon, wire, connector plugs, 3M tape and red LED strip lights, Total cost was about £10-£15.
The LED’s are red, to match the carpet
. By using connector plugs I could change the lights to white if the red didn’t work… but it does work and so well.
At the same time and while the car was in pieces, I installed the cable for the dashcam which follows the same route as the lighting cable.
Here are some pictures of the install:
Headliner removed, both A pillar interior trim pieces have to come off too.
Note the cabling on the passenger side A pillar, the driver’s side is clear so determined which side the new cables would run.
Headliner showing the cable, you can also see the dashcam plug.
Headliner re-fixed with the cables ready to drop down the A pillar.
LED light strip stuck on the footwell panel with 3M tape. The sticky on the lighting strip isn’ up to the job.
Routing the cables behind the dashboard. Once in the passenger foot well the dashcam lead goes to the 12v accessory socket. All hidden under the dash
MX5 back in the garage, job done… what a result. I am really really pleased
