Flushing a system will always leave about a gallon of whatever you flushed with in the system. In the bad old days, you would then add your premix, and top off after running, with concentrate, with a hydrometer to hand to check you are to spec.
Coolant now is premixed. Its not premixed to take account of the 1 gallon left of water in the system. You will end up coolant that is more dilute than intended. Maybe that’s ok from a cooling point of view, because the UK is not that cold a country. But the coolant does contain anti-corrosion additives, and now they will be less effective.
The coolant is designed for a 10 year service in a new engine, 5 years thereafter. Adding a distilled water flush (taking into account dilution effects) would be better. Flushing with 50-50 coolant/water even better. And flushing with FL22 top drawer.
£100 to convert to Evans waterless doesn’t sound so bad now. First flush is with solvent, to remove all water from the system, which adds to the cost. For me, the benefits were better cooling at surfaces (according to the science), better laptimes (according to the MX5 team that did it) and lack of pressurisation (according to me. I can pop off the rad cap on a red hot engine with no fear. On a practical sense, it means less stress on hose connections, and less likelyhood of catastrophic loss of coolant under pressure. Saved my engine twice now when mechanical and electrical aspects of the cooling system have let me down (stuck thermostat in closed position and corroded fan connector)).
The reason for extended changes is to reduce the environmental impact of discarded coolant. That distilled water will also need to go to waste, not down the drain, so it will attract a disposal cost, besides being a purchased consumable (would not use tap water, nor “rain water”)…
I have seen reference to “Mazda Flush Kits” (water? and Wynns?). Mercedes now have a “Citrc Acid Flush”. Its citric acid powder that you add to the water, presumably to dissolve all that scale that you think has built up despite using a long life coolant to spec.
Modern coolants don’t break down like the old antifreezes. In theory, like synthetic gear oils, they should be good for the lifetime of the car, unless contaminated. Which is a given, due to use of rubber hoses.
