What oil?
Service time
thinking miller CFS 5w40 as millers is top notch, and its a true synthetic
I do little 5 mile trips to work and back so extra protection vs a normal 10w40 seems to be a good idea
<span class="BODYcopyitalic"><br />
  </span><span class="Bold_menu">Millers Oils </span><span class="Bold_RED_menu_underLINKCopy">Motorsport</span><span class="Bold_menu"> product range </span><span class="BODYcopyitalic"><br />
  <br />
  </span>
ENGINE OIL
  <br />
  <span class="smallcopyitalic">PRODUCT NAME AND VISCOSITY:</span><br />
  <span class="Bold_TITLE_underLINKCopy">CFS 5w40</span><br />
  <br />
  <span class="smallcopyitalic">DESCRIPTION:</span><br />
  <span class="BODYcopyDARK">Competition full synthetic engine oil.<br />Formulated
with 100% synthetic base fluids, including a synergistic blend of three
esters combined with the latest additive technology for maximum
performance.
APPLICATION:
Use as received for competition or
modified engines where maximum power release is the preferred criteria.
Formulated
for high revving engines used in circuit racing or for larger engines
for short duration i.e. hill climbs and sprints.
USER BENEFITS:
• Fully synthetic oils provide many
outstanding performance benefits over conventional mineral oil.
• By
utilising both polyalphaolefins (PAO) and ester synthetics specially
selected to minimise the amount of polymer used, the lubricant film
provided is more resistant to ‘shear’ and viscosity loss in highly
stress areas.
Full synthetic oil provides:
• Load carrying
capacity many times that of mineral oil.
• High film strength for
ultimate protection.
• Outstanding cold flow properties for reduced
wear at start up.
• Excellent thermal stability and oxidation
resistance.
• The synergistic blend of three esters gives improved
lubricity, reducing friction and enhancing the oils performance.
CFS 5w40 provides the optimum balance between hydrodynamic and boundary
lubrication and the power absorbed through pumping losses to ensure
maximum power release…
PERFORMANCE PROFILE:
• Manufactured to far exceed the
requirements of API SL/CF and ACEA A3/B4.
• Ideal for fast road or
track day use, especially in engines where a 5w30 is normally specified.
Suitable for operating at 125°C with peak temperatures up to 150°C.
TYPICAL CHARACTERISTICS:
SAE Viscosity Grade … 5w40
Specific
Gravity @ 15°C … 0.862
Kinematic Viscosity @ 100°C … 14.0cSt
Kinematic
Viscosity @ 40°C … 75cSt
Viscosity Index … 190
Pour Point °C
… -30
Flashpoint °C … 210
Cold Crank Viscosity @ -30°C …
6,600cP
HEALTH AND SAFETY:
Health and Safety Data Sheet 5836
applies to this product. When used for the purpose recommended and with
due regard to the appropriate Health and Safety Data, the product should
cause no concern. If in doubt, consult with Millers Oils Technical
Department.
Millers Oils Motorsport product range
ENGINE OIL
CFS 5w40
DESCRIPTION:
Formulated with 100% synthetic base fluids, including a synergistic blend of three esters combined with the latest additive technology for maximum performance.
APPLICATION:
Use as received for competition or modified engines where maximum power release is the preferred criteria.
Formulated for high revving engines used in circuit racing or for larger engines for short duration i.e. hill climbs and sprints.
USER BENEFITS:
• Fully synthetic oils provide many outstanding performance benefits over conventional mineral oil.
• By utilising both polyalphaolefins (PAO) and ester synthetics specially selected to minimise the amount of polymer used, the lubricant film provided is more resistant to ‘shear’ and viscosity loss in highly stress areas.
• Load carrying capacity many times that of mineral oil.
• High film strength for ultimate protection.
• Outstanding cold flow properties for reduced wear at start up.
• Excellent thermal stability and oxidation resistance.
• The synergistic blend of three esters gives improved lubricity, reducing friction and enhancing the oils performance.
• CFS 5w40 provides the optimum balance between hydrodynamic and boundary lubrication and the power absorbed through pumping losses to ensure maximum power release..
• Manufactured to far exceed the requirements of API SL/CF and ACEA A3/B4.
• Ideal for fast road or track day use, especially in engines where a 5w30 is normally specified.
• Suitable for operating at 125°C with peak temperatures up to 150°C.
SAE Viscosity Grade ... 5w40
Specific Gravity @ 15°C ... 0.862
Kinematic Viscosity @ 100°C ... 14.0cSt
Kinematic Viscosity @ 40°C ... 75cSt
Viscosity Index ... 190
Pour Point °C ... -30
Flashpoint °C ... 210
Cold Crank Viscosity @ -30°C ... 6,600cP
HEALTH AND SAFETY:
Health and Safety Data Sheet 5836 applies to this product. When used for the purpose recommended and with due regard to the appropriate Health and Safety Data, the product should cause no concern. If in doubt, consult with Millers Oils Technical Department.
 That will cause no damage at all to your engine and should work fine. I use 5w 30 but if it is a MK1 or MK2 it should be fine. On a MK3 I would go for the 30 as that is what is speced for it
eddie
 The CFS 5w-40 is ideal, and we have a Millers offer running at the moment.
http://www.opieoils.co.uk/t-Current-Offer.aspx
Cheers
Tim
 Go for it and enjoyBig Smile
Dr.Eunos
