Wheel offset nd2
  1. My model of MX-5 is: __nd2
  2. I’m based near: chard
  3. I’m looking for technical help or recommendations on: __ can someone tell me if I am correct about wheel offset my car has 17 inch wheels and a 45 offset. does the 45 mean mm if so if I put on 17 inch wheels on with a 30 offset will the wheel stick out 15mm further thanks
Try this website: https://www.willtheyfit.com/ It calculates everything for you. It gets shared on another forum I use when members ask these types of questions.
excellent thanks a lot
Mazda MX-5 ND (2016-present)
Width 7 7.5 8 8.5 9 9.5 10
Minimum Offset
Stock Arches ET30 ET36 ET42 ET48 ET54 X X
Rolled Arches ET18 ET24 ET30 ET36 ET42 ET48 ET54
Pulled Arches ET6 ET12 ET18 ET24 ET30 ET36 ET42
Wide Arches ET-6 ET0 ET6 ET12 ET18 ET24 ET30
You have to be mindful of backspacing at well. I fitted ET35 15" wheels to a Mk1 with 1.8 brakes. The wheel barrel kissed the front calipers.
