Norman Garrett was a packaging engineer at Mazda (in case people think he designed the chassis); he has an impressive LinkedIn profile. A lot of what he said in that book was useful, worthwhile and correct. Some of it wasn’t. His book is very much his viewpoint, and not that of others from Mazda.
Wheel weight: How critical was it in the end when Mazda launched the Eunos Roadster M2-1001 in 1991 and M2-1002 in 1993. Both cars came fitted with Panasport Rallys; a 15x6.5" wheel weighing in at 14-15lbs. The M2-1001 was Mazda’s nippy clubman sport focussed car. So maybe wheel strength was judged to be more important than wheel weight. Panasports and other Minilite-style wheels are very strong. Lightweight wheels can be weak (cheap ones).
Hubcentric collar; bit irrelevant really. If you pick a wheel with a smaller hub opening, it won’t fit. If you buy a new wheel with a larger opening, suppliers seem to universally supply an adapter. If you fit used wheels from some other car, you are playing the safety lottery.
Offset: All Mk1s came from the factory with 45mm offset wheels, including those models with factory fitted 15" wheels (M2s, RS, R-Limited, VR-Limited, S-Special II). With the Mk2, its not quite the same story; those cars with factory fitted 14" wheels retained 45mm, but 15" alloy wheels went to 40mm. What changed?
Perhaps some of these specifications aren’t as critical as a former packaging engineer believed.
I have these wheels winging their way to me, £526 delivered:
http://www.ebay.co.uk/itm/4-Cerchi-Mazda-MX5-NA-NB-Minilite-7x15-4x100-ET35-Wheels-Felgen-Llantas-Jantes-/221878862683?hash=item33a902c35b
Correct centre bore, so no bits of plastic to mess around with/lose, 35mm offset, so nothing body-rubbing crazy, and a weight that I completely relaxed about. TUV certified to boot; not needed here, but gives some confidence in their quality.
