Hi
I didn’t want to start 2 separate threads so I put here my 2 questions.
Maybe some of you know which glue is OK to stick one of that fabric stripes above my head to the roof inside (soft top of course)
And second, where can I buy that kind of bolts like are used to seats mounting ? I want to raise a little bit my seat but I need longer bolts. Forgive my ignorance if it is obvious, but so far I couldn’t find that kind of store (online or real).![]()
I will leave the glue to others.
It is a Japanese standard (dimensions) flanged bolt with an integral 24mm diamter flanged washer on it.
Specification
M10 diameter
1.25mm pitch that is a fine pitch in DIN bolts.
14mm AF spanner size bolt head
The threaded length is 20mm with a 3mm unthreaded tip at 9mm diameter.
Material grade 8.8, do not use stainless, they should not be used on a car.
It is easier to pick up DIN (dimensions) metric bolts in the UK
The (DIN) standard dimensions tend to be 15mm AF acrose the bolt flats that is not a problem.
As the seat bolts are fine pitch they will be a bit more expensive as fewer suppliers stock them.
This one on ebay below comes with a washer which is handy as the original bolt has a built in washer and the linked one does not, therefore that sorts that problem.
I will leave you to look for a better price.
http://www.ebay.co.uk/itm/M10-Fine-Thread-1-25-Pitch-Hex-Set-bolts-zinc-yellow-8-8-FREE-NUTS-WASHERS-z-y-/332155968320?var=&hash=item4d5609db40:m:mkkyTCsF_jZnYHvM91c3AUg
Wow. Thank you for your help !
Beer or cider for you mate ! Big thanks !![]()
