Whining noise when steering right
  1. My model of MX-5 is: __nc 2007
  2. I’m based near: __chelmsford
I get a whining noise only when steering right. I’ve checked power steering fluid all ok
Is this while moving or stationary.
Only when moving and steering right
Does the noise only happen at slow speeds when turning right?
Does it go away when going faster?
Whining/squeaking when turning right (or left) would indicate to me brakes.
Noises can be a weird thing……
Check the brakes/guide pins/pads.
Make sure they are free, cleaned and greased with proper brake grease.
This would be my first port of call without an inspection based on your post.
If nothing else you will know they are good after service.
Good luck. :+1:
Many thanks for advice
