I’ve had to cut into the bottom of my rear lower control arm as the lower shock bolt is causing problems. Will this likely fail an MOT?
Depending on the severity/depth of the cut might not only be an mot failure but also dangerous to drive.
I’ll be sure to replace it then
Have you got a photo?
