Windscreen Wiper Blades - Can anyone recommend any?
One of my pet hates is streaky or uncleared lines on my screen in the rain.
I need a new set of blades but don’t want the Halfrauds extortionate rubbish.
Can anyone recommend some good performing, reasonably priced blades for my MK2.5?
Yes, go to Halfrauds and buy the Bosch blades.
You can’t go wrong with Bosch Retrofit Flat Wiper Blades from euro car arts, use code GHOST80 to get 50% off
As above, I’d get Bosch, I’ve used them for years now and found them best.
The pair on the MX-5 are due to be replaced but have been on the car since I just after I bought it in 2012. So they’re over seven years old and have been on the car 25,000 miles. They’re only going to be replaced as the passenger side blade has started to smear.
On the everyday car the first set of Bosch blades lasted three years and over 30,000 miles. I then made the mistake of buying Champion blades as the motor factors I used had changed the brand they stocked. They were initially ok but after a few months they started to squeak and smear. After a year they were replaced with another set of Bosch that are on the car now still working fine.
Thanks for the recommendations
I’ve ordered a set for both cars, with the discount
