Does it leave streaks in both the up and down sweeps? If it’s only doing it while going back down it could just be that the wipers not at 90 degrees to the surface of the glass.
I used to get this on my Capri till I used two adjustable spanners to slightly twist the wiper arm. It’s worth a look as it’s a free/simple fix.
“Are you using genuine Mazda wipers? The left hand side one has additional springs/curve to prevent this.”
That’s what I understood. The genuine replacement blades are handed with the passenger one designed to follow the curvature of the screen. They are pricey though so I just bought some Bosch Superplus and can live with the passenger side streaks as I never sit in that side anyway!
That’s the normal situation, agreed. This smearing stays with the arm, not the blade, when I swap the blades around. Starting to think it’s the spring. Off out to give it a test.
Presumably, when I try to degrease the glass, keep the agent off the rubber seals and blades etc?
Good tip, thanks - always give them a good wash at carwash time, but this is a much better idea.
OK, think I’ve cured it. Used a degreasant when I was washing car today, so flooded it with water to rinse, gave it a good soaping and flooded it again.
