Does anyone have a wiring diagram for twin horns on a Eunos that has a relay attached- I have been advised my wiring is in a word “knackered”, someone has used fairy light wiring.
Any help or even better pics would be great
Thanks in advance…
Thanks in advance…
The original wiring to the horn has a relay and adequate wiring as standard. Simply connect the air horns to the existing wiring.You may find that the fuse blows on odd occasions, if this is the case then you can, as I have, uprate the fuse to 15 amps. This is the only time that I would re rate a car fuse, the wiring is perfectly adequate for 15 amps and the relay also. Remove the fairy lights.[;)]
Thanks Geoff [Y]
