Hi Rich,
very good points. Tough the information in the brochures and manuals sometimes disagree. For example, in some materials they say the tank volume is 48L in others they say is 50L. I’ve also seen the different numbers for the minimum turning circle 9.4m and 10m. OK, I’m nitpicking…
You might be right about the gearbox. If I made a mistake, was to quote the numbers for the mk3 from my memory. My mk3 had standard tires 205/45/17 (and I also run it with slightly larger diameter tires) and the speedo was within specs, well was overestimating the speed like all do. So no issues there.
But do you really turn 3000rpm at 70mph on your mk3? I really remember I was somewhere around 3200 rpm on the mk3 …
I quickly looked at some of the logs I did with my mk3.5 and indeed the final ratio (the diff) is around 3.727 and the 6th gear seems to be 0.832 as in the brochure. Here are some data I get from my logs:
5th - 3680-3700 rpm - 112 kph - 69.6 mph
6th - 3050-3080 rpm - 112 kph - 69.6 mph
Note that this is ECU data, so the speedo will show 4-5% higher speed. Unfortunately, I don’t have the mk3 data anymore, nor access to a mk3 to test it. That would make things a clearer. Apologies if my first statement about the mk3 was wrong.
I didn’t state that the mk3.5 engine has more power. I said it pulls stronger. Peak power numbers are not saying all the story. And the fact that they quote the same power for both models in brochures has more to do with emissions and saved Mazda from re-running EU tests, etc. Is the power curve totally flat between 6700 and 7000 rpm? It doesn’t change to 161ps or 159ps? To me it looks like the way they show the numbers is to show that the redline and the rev limit was increased.
Also, the US specs for mk3.5 with the same engine is 167ps. Granted, they have different maps/tunes for different states due to emission regulations. But still, the mk3.5 was introduced there with an increase in power. And it is mechanically the same engine as here. So what I’m trying to say is that the specs Mazda put in the brochure are just a guide, probably conservative, and not absolute numbers.
Finally, if you tune both engines you get rather similar results, though most tuners (and customers with remapped engines) quote better numbers for the mk3.5, some are due to higher rev limit for the mk3.5 (but again that shows that the torque is not dropping that much at top to have a flat power curve).
Regarding the DSC, I also find it was less intrusive in the mk3.5, but that has to do with a lot more things, suspension, geometry, how good your diff works, tires, etc. But it was something that I noticed and I was trying to upset the car just to see if it works. But hard to tell if they update the DSC software between versions.
Probably I’m biased in my review, but I really loved my mk3 and I was convinced there is not much difference between the mk3 and mk3.5, but for me all the tiny revisions makes the mk3.5 a more refined car (bar the annoying bluetooth button on the steering wheel which I wish it was mute as before and the rather pointless engine sound induction system on the sport models …).
And one last thing. I find the cruise control on the mk3.5 a good to have option. I don’t use it that much, but if you do long motorways trips it will be handy. And is not that cheap to add it to a mk3.5.
OK, I’m done :).
Adrian
