One thing to consider about a twin exhaust; you might not like the sound. It requires the bumper to be cut. Most fitters seem to make a complete hash of cutting the extra outlet, and you will be forever bothered by the jagged edges. And you end up hating the sound, but its not so easy to go back to OE, because now you have to replace the entire rear facia as well. Keeping to a single exit exhaust will at least give you the option of changing your mind.
I changed the rear bumper cover recently on my 96. The original I had carefully crafted the extra outlet, and had it perfect. But that bumper had always suffered poor paint adhesion, due to an history bump on it, and the paint just fell off (the paint always fell off at the same spot). I had a spare bumper that had been already trimmed by someone else for a twin exit. I think he must have used a woodsaw, as its so jagged. And the MX5parts twin exit I have is horrible, can’t wait to get shot of it. I forgot to mention that because a twin exit was never intended by Mazda, depending on how its fitted, you might end up with off clonks, especially when cold.
As for FI, whatever form, every example I have come into contact with, has required extra maintenance, always fixing something that has gone wrong. When the factory Mazdaspeed turbo NB-FL was launched, I recall all the enthusiasts complaining why it was such low boost. The engine used in those cars was basically a different engine to other NB-FL engines. It wasn’t a VVT for a start, it had different pistons, beefed up crank etc. Mazda expended a lot of effort ensuring these cars were as reliable as the regular cars. ie. the implication was the bolt on kits could not offer the level of reliability expected by Mazda (9000 miles between oil changes etc). FI is fine, because hundreds of owners benefit from it, but it must surely change how you run the car, and becoming more involved in spannering yourself.
Lowering springs only. The issue with fitting lowering springs only to OE shocks is now the shock is partially compressed. It won’t be working particularly efficiently, potentially the service life is shortened. A lowering spring is, by definition, firmer than stock. And then you have considerations of progressive versus non-progressive springs. And you’ve paid the same labour to fit those as you would complete shock-spring units.
With £5k, I would:
1. Racing Beat Racing Beat Header, Racing Beat Power Pulse Single Tip, Racing Beat connecting pipe; that little lot will come to £1000. I consider the Racing Beat kit to be the best quality out there. In 2000, I had the good fortune to drop in Racing Beat’s Anaheim facility. Anyone on holiday to California Disney, should do so. They love visitors, and have a lot of cool stuff going on. I was given the tour, saw the founder’s Bonneville salt racer RX7 Convertible (and it wasn’t a factory convertible; the owner built his own around a spacefame chassis), the prototype NB-FL body kit RB was working on (with Mazda). I met the guys there who made the headers, and the old boy who’s job was to assemble and test every single one of their plug wires. And I got a free shirt and hat as part of the tour. £100 or so to get fitted. Cobalt and MX5parts exhausts are NOT top quality.
https://www.youtube.com/watch?v=uu_QeHrKY1E
- Autoexe Cold Side Induction(Rev9). In the end, its just a K&N kit, but has a beautiful carbon fibre shroud, and moves the intake away from the exhaust, and shortens the intake tract, making the throttle a lot more responsive. Probably thick end of £500 delivered. £50 to get someone to fit it for you.
- Upgrade the cooling probably a good idea. Good quality branded aluminium radiator is £400. Beware of cheap Chinese efforts.I would recommend changing to a waterless coolant (Evans). Coolant change is £100, £100 to fit the radiator
- Suspension: Contentious. If I had the budget, I’d go for a Tein Flex-Z kit, with the EDFC option, because who wouldn’t like control of shock settings from the dash. And its Japanese quality.
https://uk.tein.com/product/flex_z.html
That’s another £1000 gone with the EDFC stepper motors. £400 to fit? Racing Beat Europe are a Tein dealer.
Anti-roll bars; avoid the tubular bars, as they can get drivers into trouble (know of a police driver who cornered so hard with these things, that the bead came off the rim without warning, and the car ended in a ditch). One thing to be aware of; the front ARB mounts on the NB can be ripped by aftermarket bars, hence RB supply an additional reinforced mounting fit. I would probably pass on the upgraded bars.
Next would be wheels and tyres, and £100 or so spent on a proper alignment. And at the end of the day, you’ll will have a very nicely set up reliable MX5. But note, you will never see the money spent on the upgrades back.
