- My model of MX-5 is: __an nc2 sport tech
- I’m based near: __manchester
- I’m looking for technical help or recommendations on: __the best fuse to used for a permanent dash cam fitting.Any help or advice would be appreciated
Dave
Dave
Hi Dave, @Jamesy1 assume you mean which fuse in the fuse box to piggy back onto. These are mostly ignition switched live not permanently live. I’d recommend something like the cigarette lighter accessory, interior light or similar. Something you can live without if blows. On our Golf, I hardwired it via the cigarette lighter fuse. In my Nd i just used the actual cigarette lighter/accessory socket in the passenger footwell.
There is also a thread on fitting on an ND … I know you have an NC, but same concept where @kool4katz use the mirror fuse , see…
https://forum.mx5oc.co.uk/t/tutorial-nextbase-dash-cam-hard-wire-installation-mx5-mk4/101335
… hope that helps an I didn’t misinterpret the question. … Rich
I’ve just wired one in, use fuse position 2 for your piggy back connection. That’s in the secondary fuse box at the bottom of the passenger A pillar.
Thanks mick I think that’s the best one to go for
Cheers
Dave
