I have an older type of car as well as the Mk1 Eunos…I just turn on my headlights on busy roads and motorways and if the average light level is low…simples.
I’m thinking if doing this, where do you wire them into?
Take the front part of the wheel arch liner off and you will find the plug there.
i fitted DRL’s from MX5 parts all in it cost 250 smakeroons but i love the look. They come on when the car is turned on, the light have a square outline through the lens so quite fancy, they stay on on dipped beam, go off on main beam, then act as a fog light with a full beam output when you turn the fog light on. i had to change the stalk for this function.
As they dont require the light switch to turn them on, the dash does not light up, so there is no forgetting to turn your lights on when its dark.
