Well I ended up buying this car in the end for a very reasonable price. I trusted the guy and I think my instincts were reliable. I have since checked the oil and other fluids more thoroughly which shows very slight discoloration but otherwise clean as though changed recently. Brake fluid was clean, coolant clean and airbox had a brand new bosch filter in it. I have been provided some independent receipts that he found that check out and he has offered to send any more as he finds them.
The underside appears very solid indeed, with little to zero rust on the actual chassis, arches or sills anywhere and mostly limited to control arms, subframe and brackets - surface only aside from the subframe support braces which I will change as I know they suffer the worst.
Car drives great and sticks very well, has a few minor jobs for me to tidy up but I’m happy to do them and will keep me busy. Some minor bodywork niggles which are small, and some minor pickling on the hard top cover, hard to spot, but I saw this on almost every car I looked at to some degree.
I will introduce myself and the car properly soon and document the changes as I make them. It’s been quite some time since I bothered with forums, but this seems to be quite an active community and I’m looking forward to contributing.
Will become a paid up member shortly
